Telltales are small threads of wool or strips of light fabric that indicate the airflow around your sails.
They are a valuable (some would say invaluable) aid in making sure your sails are trimmed correctly to the conditions (or that you are sailing correctly to the chosen sail trim).
The most basic set of telltales is as shown in the picture:
- Telltales
- Telltales.gif (18.04 KiB) Viewed 38906 times
For the main, place one telltale per batten pocket at the leech. The goal is for all of them to stream happily aft, while the top one may flick forward part of the time. Especially on a reach you will notice that it makes a difference whether these are flying correctly or whether you have the main oversheeted or let out too far. If you have a vang, you should be able to see the telltales react as you adjust it. What the telltales indicate is that the airflow over the main has remained
attached all the way to the leech. It is this attached airflow that translates the wind force to your sails.
In all but light (except: very light) winds, you may need to tighten your
outhaul a bit to make the sail flat enough so the belly doesn't cause the air flow to separate. This should be something that you can observe in the right conditions with the lowest telltale (the outhaul acts mostly on the foot of the sail). In very light winds, you tighten the outhaul so that the flow stays attached. In light winds, you allow a belly to form to get a bit more power. In stronger winds you tighten the outhaul to flatten the sail to reduce power: at some point you already have more power than you need and the goal is to reduce heeling force.
For the jib, place one set of telltales of opposite color about 1/3 up and 18" from the luff on opposite sides of the sail. Usually, the starboard one would be green and it would be placed a bit above the port one. The goal is to see both of them streaming aft, but the windward one (in this picture the starboard one) is allowed to rise or flicker a bit. (That would indicate that the trim is for optimal upwind sailing.)
When sailing
close-hauled, the jib is sheeted in as much as possible without pulling the jib too flat. The only possible adjustment would be to let it out (and sail a bit lower). So, instead of changing the sail trim, you would steer in response to wind shifts: if the windward (inside) telltale rises, you would fall off, and the reverse, if the leeward (outside) one does -- you steer away from the rising telltale until both are flying again.
If you are
on a reach and want to maintain a fixed course, you would trim the sail instead: if the windward (inward) telltale rises, you sheet in, and the reverse, if the leeward (outside) one rises; you fall off. Both the steering and the sheeting change the
angle of attack of the jib in the same direction based on the feedback from the telltales.
It may be challenging to find a seating position where the helm can monitor the jib telltales, but it's worth it.
Some boats have
Barber inhauls that can pull in the sheeting angle of the jib without adding to the jib sheet tension. This is an adjustment for moderate air 6-10 knots. For lighter air, leave them out, and also let out some jib sheet for a rounder shape (to generate a bit more power), except for the lightest airs where a flat shape is needed to keep the airflow attached. In that range, the jib car also goes forward to allow more twist (see
laminar flow). For stronger winds, let out the inhauls as well and sheet the sail tight for a flat shape (with jib car forward to allow the top to twist off to depower).
Sometimes additional pairs of telltales are placed on the jib at various heights above the first set. These can be used to check that the
twist of the sail is correct: moving the jib fairlead fore and aft changes the twist and when set correctly, both sets of telltales should fly simultaneously.
