Daysailer 3 missing mast-mounted ring to clip halyard ends
Postby tfam » Sat Jul 06, 2019 2:17 pm
I have replaced my Daysailer 2 with a 3, and find that the mast mounted ring to which the halyard ends are clipped when not attached to the sails is missing. I presume that this fitting was abandoned, because it sometimes interferes with the jib when tacking. What alternatives are there for securing the halyards so the fitting end doesn't run up the mast?
tfam
Re: Daysailer 3 missing mast-mounted ring to clip halyard en
Postby GreenLake » Sat Jul 06, 2019 8:49 pm
You can easily source and retrofit another mast ring. Contact D&R Marine. Also mainy stores/sites catering to sailboats have parts like that.
