Running wire under starboard bench.
PostPosted: Mon Aug 26, 2024 8:17 am
by Stewart711
Hello
I want to run wire from transom to cuddy on a DS2 under the starboard bench. Is this possible or is it packed solid with foam?
Re: Running wire under starboard bench.
PostPosted: Mon Aug 26, 2024 2:04 pm
by RaleighRancher
It's got foam blocks cemented to the underside of the seat or flopping around loose, depending on your boat. In mine they're about 50/50 still cemented in place or loose.
There are a couple of stringers in the vertical and horizontal surfaces of the seat. This picture from the facebook daysailer group shows it well:
transom xsxn.jpg (437.13 KiB) Viewed 4204 times
Never done it myself, but that big round stringer sure looks like a nice conduit for a wire...
PostPosted: Tue Aug 27, 2024 5:58 pm
by Stewart711
Wow! Thank you so much for the info.
Thanks again!
