Chainplate/ Chainplate screw failure
Postby Moose » Sat Jun 05, 2010 11:08 am
I was out sailing yesterday when I noticed that one of the bolts on my side-staysnapped off at the head. Anyone else have this problem?
I dont think the stays were set too tight. I also don't know about the origin or quality of the bolts. Probably replace them all with 316 S.S. BHCS's
Moose
Postby algonquin » Sun Jun 06, 2010 11:26 pm
I haven’t had this happen but it does bring to light the importance of regular inspections of the rigging and all its attachments. Especially as the fleet ages. Brad
"Feather" DS1 #818
algonquin
Postby K.C. Walker » Mon Jun 07, 2010 9:36 am
I've definitely had failures in stainless steel fasteners due to corrosion. My stemhead plate cracked and looking at the cracked place it definitely looked rusty. I also had a turnbuckle bolt shear off, and looking at that it also looked rusty and obviously had been cracked. I think 316 bolts are a really good idea. Saltwater and stainless definitely has a lifespan. Threaded parts are more vulnerable from what I understand.
KC
Postby GreenLake » Mon Jun 07, 2010 11:01 am
SS corrosion is accelerated by salt and oxygen depletion (the oxygen is needed to constantly restore a film of surface oxides that make the material stainless). Crevices and crevice-like places, like treads, are the most vulnerable, esp. for saltwater use.
Postby Woden » Wed Jun 09, 2010 3:59 am
I popped the head off of one of my chain stay bolts last year. I drilled them out and replaced them with 1/4 SS bolts. No problems.
Pete
Woden
Postby Moose » Wed Jun 09, 2010 7:51 am
I plan on replacing them(all of them Friday. Hopefully that will stop any problems.
Moose
Postby talbot » Wed Jun 16, 2010 11:12 am
I have found the #10 bolts don't align precisely, and that after use the heads are tweaked out of line. I didn't drill mine out, but have taken to replacing them each spring.
