floorboards for DS1
PostPosted: Tue Aug 22, 2000 8:16 am
by Guest
I have a DS1 which was purchased recently. The serial number on the forward bulkhead in the cuddy indicates a manufacture date around 1965. Were wooden floorboards part of the original design? And if so are they available anywhere?
mike (mgreen-at-gdsys.net)
PostPosted: Thu Sep 07, 2000 1:14 pm
by Guest
I have a 67 DS1 with floor boards, which I bought from the original owner. He said they where they an option when he bought the boat. In mine there are four sections, it is my understanding the there was a fith section at the stern behind the seats, but it is missing in mine. It also had a combination oar/mast cradle that fit into a slot in the 2 aft sections.
Kevin O'Neill (ko_-at-bellsouth.net)
PostPosted: Tue Sep 26, 2000 8:30 pm
by Guest
Kevin is right. My DSI has a fifth floor board in the stern just as he describes it. I'm not the origional owner so I don't know if it was standard or an option.
The only person I met who got a new set of floor boards, made them using an existing set as a pattern. It doesn't look that complicated. I wouldn't think that the boat is very comfortable without them as there is no place for the bilge water to drain off.
Steve Max
Steve Max (75264.153-at-compuserve.com)
