Gunwales
Gunwales
Postby bluem27 » Sun Jun 26, 2005 11:07 pm
What gunwale guards were used on the ds1 with wooden coamings.
I have simulated molded in planks on foredeck and interior floor
Was this boat designed with spreaders. None are on my mast.
Do you know what year these boats were made?
Thanks, Bob
bluem27
Postby wharfside » Fri Jul 15, 2005 1:19 am
I am a novice on the line, but anyway here goes, any idea what year your boat is?
1992 Sunfish Laser Daysailer #14002
1984 26' Bertram Sport Convertible
2004 12' Carolina Skiff
wharfside
ds1 gunwales
Postby bluem27 » Fri Jul 15, 2005 1:51 pm
Do not know year. On my last chat I posted all the info I could to determine the year. Do you know what gunwales were used on the early models or From the 70"s?
Thanks, Bob
bluem27
Do you have a HIN imprinted anywhere
Postby Roger » Fri Jul 15, 2005 11:12 pm
The HIN will give you an idea of when it was built.
Roger
HIN
Postby bluem27 » Mon Jul 18, 2005 5:12 pm
Where can I find that? Not On Stern that I can find. Thanks, Bob
bluem27
no HIN before 72
Postby Roger » Sun Jul 24, 2005 1:28 am
If it was built prior to November 1972 it may not hav a Hull Identification Number.
Roger
Postby Phill » Sun Jul 24, 2005 1:58 pm
Hello Bob,
The only DS1's with molded in plank lines on the foredeck that I have seen are the oldest '3 digit' boats built in the early '60's. If that is what you have, don't dispair, more NA Championships, including this years, have been won with this series of DS's. Many of these are difficult to get numbers from. As to your question about spreaders, YES, there should be spreaders on the mast! If you have a mast that was originally from the manufacturer for your boat, there should be some brackets or, at least, holes in the mast where the bracket and the tangs were located. If you look at the Handbook portion of this site, you can find the designed locations for these fittings.
Good Luck
phill 8)
Phill
Postby Bob Hunkins » Mon Jul 25, 2005 2:41 pm
Other ways to identify the old three digit boats that I can think of:
- Does the mainsail have a number on it (obvious)
- Is the space below the combing in the cockpit covered over, unlike the four digit O'Days? That change came about and some argue the boat is less easy to right after a capcize.
I have an old boat which I believe to be class # 1795. The plate is gone so I got that number from the previous owner by word of mouth. There is, however, a serial number molded into the fiberglass on the starboard bow just below the hull to deck joint. It won't tell you the class number but if you need a number for registration purposes it should answer.
good luck!
Bob Hunkins
#11750, "Surprise"
San Leon, Texas
Bob Hunkins
Site Admin
extra spreaders
Postby bruce cornell » Mon Aug 29, 2005 1:26 pm
your boat may also have a second pair of spreaders above the regular ones, stays start at the mast head and run to a pair of 6 inch spreaders and then back to the mast. small spreaders face forward on the mast, at about 30 degrees each side of center of mast.
bruce cornell
